Hi Guys!
This is my first post, so Hello.
I am very inexperienced and do not know what I need to expand my setup.
I live in a small apartment now and use a receiver with two JBL 880L speakers. Sound great, never need to put the volume over-5dba. really loud at that. Use a cheap sub woofer too. that does what i need. Im moving to a house and want to buy two JBL 830 bookshelves to use as surround on stands behind the couch. 880Ls in front of the couch L and R with tv mounted. I use for movies and music.
Have:
YAMAHA RX-V573BL 7.1-Channel
80W per channel (8 ohms, 20 Hz-20 kHz, 0.09% THD, 2ch driven)
http://www.newegg.com/Product/Product.aspx?Item=N82E16882115375
Two JBL 880L 400W
http://www.jbl.com/estore/jbl/us/products/Studio-L880/STUDIO%20L880_JBL_US?skuId=L880-H_JBL_US&searchMode=regularProductOnly&sCatId=cat140013
Audio Specifications
Maximum Recommended Amplifier Power: 200W
Power Handling (Recommended): 100W
Power Handling (Peak): 400W
Nominal Impedance: 8 ohms
Crossover Frequencies: 700Hz, 5000Hz, 20kHz
Frequency Response: 30Hz-40kHz
Sensitivity: ([email protected]) 91dB
Looking to get:
two JBL 830
http://www.jbl.com/estore/jbl/us/products/Studio-L830/STUDIO%20L830_JBL_US?skuId=L830-H_JBL_US&searchMode=regularProductOnly&sCatId=cat140013
Maximum Recommended Amplifier Power: 150W
Frequency Response: 48Hz-20kHz
Crossover Frequencies: 2500Hz, 20kHz
Power Handling (Recommended): 75W
Sensitivity: ([email protected]) 90dB
Power Handling (Peak): 300W
mounted on: http://www.amazon.com/Sanus-Systems-NF30C-Natural-Foundations/dp/B00133TUK4/ref=sr_1_1?s=furniture&ie=UTF8&qid=1393949565&sr=1-1
Now the big question is, is it worth it to get the two surround with the receiver I have. Will the two front channels be underpowered? I have no extra money for a new receiver. Whats the deal with amplifiers, i see my receiver supports it for the two front channels. And can someone please explain how the high and low frequency inputs work on my 880s? My livingroom wont be too big i just need to know if I made a bad choice with this receiver. I know amps can cost alot, and hope to hold off on buying one till i need to power the front channels in my basement in the far future when i build out my home theater.
Thanks in advance.
Hi Guys!
Have:
Two JBL 880L 400W
Looking to get:
two JBL 830
Thanks in advance.
