Hi,
Im on catalyst 10.2 and decided to set up 3 profiles for automatic resolution switching via reclock for each common movie rate being 23.98, 25 and 59.98.
Testing switching via CCC and activating the profiles from 25 to 59 and back work fine but trying to get the 24hz profile to output 23.98 as it should won't work correctly, it outputs 24.99hz.
Looking at CCC display setup whilst activating profiles i can see that it changes to 24hz but then flickers to 25hz and outputs 24.99.
Manually selecting 23hz output in display properties, changes to 23 but flickers to 24 and outputs 23.976 correctly, just using the profile for it won't output the correct frame rate and sends out 24.99(25hz)!
Any help? anyone get the same with 10.2 drivers and a 4870 card?
