Hi folks. I am having to re-build my home theater after a basement flood.
Can anyone tell me the proper projector-to-screen distance for the BD808 using a 92" wide screen?
Also when I go through the "installation adjustment menu", the raster centering concerns me. When you get to this adjustment in the sequence, the contrast is turned down and you have to look into the lens and see if the raster is centered in the phosphor area. In my case, where the raster is at its widest, it's wider than the phosphor. When you center it, it still spills off the phosphor on both sides. Also, at the bottom of the raster (as you look from the front) the raster looks bent.
As I continue through the adjustments, I can get the actual projected image to look pretty straight and to fit inside the phosphor area, but it doesn't seem right that the raster itself looks this messed up.
Thanks for any insights/suggestions.
