Sorry if this has been discusses before but I could not find it....
As we all search for the holy grail in terms of sound, I have decided that my money should now be spent on my room...more specifically acoustic treatments. My dedicated space was not built specifically for my theater but it became my theater and as such changes in structure and or shape cannot be done, so acoustic treatment (I believe) is my first alternative.
I have begun doing research and have come across room modes or resonance. In plotting my dimensions in the various spreadsheets or formula's, I have determined that along the lenght axis, I have a resonsnce at 24hz. My room dimensions are:
23.6' long
11.9' wide
9.7' high.
I should point out that along the length, I do have an opening that goes from floor to ceiling and is 6' wide that is covered with black draperies. This was a WAF decision as she did not want a door placed here for aesthetic reasons. The draperies do look very nice but I'm sure the opening has effects on the overall acoustics of my space but I have to work with what I have.
I also know, these are not perfect dimensions for proper spacing of room modes but (again) I have to work with what I have.
So my questions are:
1.) In determining how to properly bass trap my theater would it be true that the traps would have to be able to absorb down to 24hz to be effective in my room, since this is where my resonance is along the length axis?
2.) If I can effectively trap that low will it also improve the bass across the other two dimensions of my room since my resonance at the width is 47hz and at the height is 58hz? This is assuming I place four traps in the 4 corners of my room.
3.) Does it really matter because is it really possible to get usable bass that low in a room my size? If I get a trap that's rated down to 50hz would it be just as effective or a waste of money?
I'd appreciate any input (or questions) on this as I continue to delve into the realm of room acoustics.
23.6' long
11.9' wide
9.7' high.
