Help with code for SA Explorer 4200
492 Views 2 Replies 2 Participants Last post by  Scallica
Hi everyone. My first post here but I've had my replaytv (5040) for a couple years. Anyway, I had a question concerning my cable box. I am in NJ, Cablevision, and they made me get a new digital cable box (Scientific Atlanta, model Explorer 4200) today. So, when I hooked it up, i can't get the ir blaster to work on any of the codes suggested. I was wondering if anyone had this cable box and had success getting the ir blaster to work. Any help would be appreciated. Thanks.
Pete
Status
Not open for further replies.
1 - 3 of 3 Posts
Nevermind, i did the fine tune thing and it now works. Thanks anyway.
Pete
Hi Pete....welcome to the forum. It is always a good idea to use the search feature before posting.
Here is a previous thread that should help you:
http://www.avsforum.com/avs-vb/showt...hlight=SA+4200
1 - 3 of 3 Posts
Status
