Im trying to connect my computer to my HDTV via a HDMI/DVI connection. Im using a X850 XT PE if it matters.
Anyways I connect my PC to the TV and I have no trouble getting a source and I do get my desktop on the TV. But when I switch the display to a resolution of 1920x1080, all the edges get chopped off like a cm(if it were on a regular 17 inch moniter)
Ive tried using the Powerstrip 3.7 to shrink all the sides of the screen, but then my TV gets an error and says Source not supported. If I use powerstrip on a regular 17 inch monitor, the sides can shrink.
Anyway to get this to work?
