1 - 5 of 5 Posts
Really need help with this one!
Just bought a 50 inch plasma from circuit city. I am going to be putting it in the corner of my living room since it is the only place condusive in the room. Problem is, I am having alot of difficulty finding a wall mount that will work so that it will be centered in the corner.
I have looked all over the internet, but I am sure there is a expert out there that knows better. I want the most INEXPENSIVE mount as possible. They told me at Circuit city that I need to pay 550 bucks, but then I go to monoprice.com and they are VERY cheap.
Does anyone have any reccomendations?
Thank you VERY much for your help!
Would a ceiling mount be feasible in your case?
1 - 5 of 5 Posts
