Status
Not open for further replies.
1 - 1 of 1 Posts
I currently have an 18x24 oval dish that is set up as round dish tracking the 101 sat. The 2 drops from the sat feed a 3x8 powered multiswitch. I just ordered the HDTV dish upgrade with receiver. Couple of questions:
1) I think the 3x8 ms is worthless with the 3 LNB dish. I need 4 inputs?
2) I think the installer will supply a 5x8 switch that cascades off the dish's internal multiswitch?
3) I really need more than 8 outputs. Can I add another 4x8 cascading switch using 4 outputs from the first multiswitch? Does this degrade the signal? I really don't want to buy a 12 or 16 switch because of the cost.
4) Would it be better for the installer to add a SAT C kit and repoint the dish to pick up all 3 sats?
Suggestions/advice is appreciated!
1 - 1 of 1 Posts
Status
