Status
Not open for further replies.
1 - 1 of 1 Posts
Hi, I've been dealing with this problem for a lot of time and I need some help and advice.
I'm trying to send the audio output from my HTPC (W2K, Zoltrix Nightingale Pro 6 audio card using coax SPDIF output, TheaterTek and playing a DTS DVD) to a Rotel RSP-1066 receiver.
I've only been able to obtain a Stereo signal.
I've tried all this:
- Enable SPDIF output through the "mixer" software from the audio card. I've also set the 2-speakers option.
- Configure TheaterTek with:
- Output : SPDIF
- SPDIF Device: I've tried all the possibilities (C Media Wave Device, default direct sound, default media wave, Sonic cinemaster, ...)
- Preference: DTS
In most cases, the TheaterTek configuration panel loses the settings when I restart the player and resets the "Dolby Prologic" output option.
Only in one case (selecting Sonic Cinemaster SPDIF device) I achieve to maintain the settings but no sound goes out from the Rotel connected speakers.
Any suggestions ?
Thanks in advance.
1 - 1 of 1 Posts
Status
