Status
Not open for further replies.
1 - 2 of 2 Posts
I've been a member of this forum for around a little over a year, visiting the Rear Projection and HDTV Programing forums quite often. My living room is set up with a GW11 and HD200 Directv stb. I am now ready to take the plunge into plasma for the bedroom. After reading many posts here over the last two weeks, I am more confused than ever.
Here's what I'm looking for.....42", with attached or attachable speakers,(wife says no home theater set up in the bedroom).....We will be using a HD200 or 300 stb and Sony DVPS7700 dvd player. Price range for the tv is $5000- $6000 from a store with four walls and a parking lot (no internet purchase). Timeline is between now and the holidays.
I thank you all in advance for your help....
Moderator
Don't worry about the speakers. There are more than a couple
companies that make speakers that mount nicely around a plasma.
I believe in your price range you can get just about any 42" plasma
you want.
larry
1 - 2 of 2 Posts
Status
