1 - 1 of 1 Posts
A couple of question:
I'm using DVBViewer to record programt etc. Hovever the files are in ts format.
1. Which program can I use easily and WITHOUT compromising with the picture quality to get from TS to DVD?
2. I'm also recording HDTV from Discovery HD but there are often commercials, so the files get quite large. Which program is the best to edit HD without compromising with the quality and keeping the DVB subs?
2a. Have tried TS package editor, but when I try to play in Zoomplayer or in DVBViewer the subs is not available, but however when playing in VLC they are showing. How can I fix that, cause I'm using the two programs the most.
1 - 1 of 1 Posts
