Hey all, I got an ep2500 for my av15h. Right now it's in a sealed 4 cu ft cab. I have a sony str-444 es receiver sending sub out to a cheap behringer mixer (until my mic2200 comes in) then to the amp. It seems the amp clips prematurely. I tried turning the sub volume on the receiver up and messed with the dials on the mixer but it clips. The lights on the mixer are clipping so I think it's sending a clipped signal to the amp
The sub is dual 2 ohm for a total of a 4 ohm load. The amp is bridged so I should be able to get around 2000 watts out of it, but my old 300 watt bash drove the sub harder. After very little play time (with a quite a bit of the clipping light coming on the amp got quite hot. Any thoughts?
Dan
Dan
