Hello, I'm having difficulty getting the mechanical focus set on my NEC projector. If I set mechanical focus so that the center is sharp then the edges are blurry (kind of a fish eye effect), and vice versa.
I read Guy Kuo's article and focus and it mentions two mechanical focus adjustments (edge and center). The only focus I have found is by loosening the two wingnuts and rotating the plastic part around the front of the CRT.
If someone could point me in the right direction I would really appreciate it.
thanks.
thanks.
