Thats not too much history on the situation, but statistically and typically it is the hard drive.
Replacing one is eaasy to do. look at the little video in this link.
http://www.avsforum.com/avs-vb/showt...hreadid=416831
I recommend using RTVpatch version 2.4. Some people seem to have probem with the newest RTVpatch program and the steps in my little video doesn't quite match the newest version.
I recommend seagate drives, then maxtor. If you plan to use a different brand snoop around here to make sure it is compatible first.
You can get the best HD deals using rebates. HD deals are often posted here, particularly around weekends when the ads come out.
