I have been researching an antenna for a couple of months and would appreciate some help. This is the map of the HDTV signals I can receive
http://members.aol.com/phansson/antenna
The stations that I would like to receive are as follows
Abc #21 on map
Cbs #18 on the map
NBC #27 on map
All of which are within 40 miles from my house. All are UHF. The problem is how do you receive all 3 signals? I have had no luck with multi directional antennas. Would I have to mount two uhf antennas?
Has anyone tried the square shooter?
Thanks for the help.
Abc #21 on map
Cbs #18 on the map
NBC #27 on map
