1 - 2 of 2 Posts
Ok, Dont know if tis is the right place for this or not but here goes. I just bought a new Travel Trailer. It has eight speakers built in to the roof of it and has a nice Jensen head unit that is a AM/FM/CD/MP3 Jack. It did not come with a flatscreen TV but it has a nice cut out in the entertainment center for one to be wall mounted and also has the outlets and cable input right there so the wiring can be hidden. I am looking at installing a toshiba 22" lcd with the dvd player built in and would like to have the audio through the existing speakers in the trailer. I need your advice. The only audio in in the back of the Head unit is an auxilary input with a red and white left and right hole. The only output on the tv is either a headphone jack in the back or a coaxial digital out. Do I get a cable that plugs into the headphone jack and splits into the left and right? Or is there anything that exists that takes the digital coaxial and splits it into a left and right? I know that the cable exists to do the first, but how would the audio sound going from the headphone jack to the head unit? Thanks for the help.
No analog out? The head phone jack is your best bet. Hard to believe the display does not have R/L output especially if it has a built in DVD player.
I see they put the headphone jack in the rear, so this effectively your analog L/R out as well. Cheap adapters readily available for that for sure.
I see it has an optical digital audio out. Normally that would be what you would want except in your case.
1 - 2 of 2 Posts
