Status
Not open for further replies.
1 - 4 of 4 Posts
Okay I have the Polk 202 powered Sub and the new Pioneer 912k receiver. My problem is how do I connect the Sub it has a left and right RCA type input and speker wire terminal left and right in and out. This Pioneerrec. does not have a sub out with both left and right outputs. This is were I cannot figurei=out how to connect. Any ideas?
Mark
The sub should tell you. but either use a y adapter or connect into the left or right on the sub. with the M&K MX 350 it tells you to plug into one i forget if it's left or right. so yers would be the wame way.
1 - 4 of 4 Posts
Status
