Status
Not open for further replies.
1 - 3 of 3 Posts
· Registered
I've been thinking about setting up an htpc, right now I'm in the market for a video card, and a tv capture card. My Mist. TV will accept rgbhv or regular component inputs. Can I use VGA out to the rgbhv with a vga breakout cable? Thus saving purchasing the ATI dongle , will this set up limit resolution on DVD playback?
And what video cards would you recommend. If this would work I would like a card with dual vga outputs so I can connect the Mits, and a regular monitor. I was thinking about the ATI 9600, but it looks like it have one VGA and one DVI, my LCD monitor doesn't have a DVI.
Please help.
Thanks a bunch,
· Registered
I have an ATI 7500 all-in-wonder card which only has DVI out, it came with a dvi to vga adapter to go into a regular monitor. you shouldnt have any problems hooking up your two display devices that way.
1 - 3 of 3 Posts
Status
