A simple splitter/combiner will do what you want.
Originally Posted by biker19 /forum/post/15400400
That makes no sense - you want to watch an SD signal on an HDTV from an HD receiver? Can't be bothered with another Dish receiver?
The device suggested above might work.
After googling to learn about this Television, I have read where a manual entry of OTA channels on this Television was not possible. I thought maybe someone had accomplished this on this particular forum.Quote:
Notice I said I wanted my OTA Channels for prime time HD. Also, I am waiting on delivery of Television; Its back ordered but I have downloaded the Manual for my own learning curve. Jan.6 2009 is delivery date. It was purchased for me as a gift.
I will eventually get a HD Receiver for my bedroom but financially I need to wait a few months but thats actually none of your business right?
The device suggested above might work. While the TV may not have manual entry for digital chs, I know of no TV on which can't enter an analog ch. (like that 60 you're looking for). Did you try it?
Originally Posted by gerhard911 /forum/post/15400547
I knew somebody would take him to task for what he wanted to do. Maybe he wants the Dish output on the RF in for PIP ? Why second guess his desire ?
No, it WILL work![]()
Originally Posted by gerhard911 /forum/post/15403437
You are welcome. You would probably have a better shot at an answer to your second question over at the plasma display forum .
Originally Posted by walford /forum/post/15403753
Smackman,
Why do you want all of the digital SD and HD programs you receive with your HD dish receiver send to your 720p HD TV in SD 480i resollution over coax instead of in digital SD or HD over component or HDMI? Then you could use an antenna for tge OTA digital tuner in the TV.
Originally Posted by smackman1 /forum/post/15398761
I want to hook it up to my Dish 622 HD Receiver with the SD output which is Channel 60. I have a RG6 coax Connector for this.
Originally Posted by jtbell /forum/post/15404087
Is this the only output the Dish receiver has? If it has any other outputs, why can't you use one of those with your TV? Just curious...
