1 - 5 of 5 Posts
· Registered
Im well aware of the inaccuracy of copying settings due to different environments. However, Im just at an absolute loss with my display. Its a 32lm57bpua 720p lg 32 inch. Can anyone provide the display settings for gaming on console with this tv? Games look too dark or too washed out with defaults.
· Registered
Try doing a forum-wide search for your TV's model number. If nothing comes up, either no one here has one, or does but hasn't bothered to post anything about it.
There's no single group of settings that will make dark content brighter and bright content darker. Since you aren't calibrating, just adjust things one at a time until they look good to you. Many games don't really follow video standards anyway, so you'd still need to adjust to taste as required.
· Registered
Discussion Starter · #3 ·
Thanks for the reply. Ive noticed. Especially in Skyrim. So heres what Ive got backlight matches contrast 58. I dont know what to set backlight to. So anyways backlight 58 contrast 58 brightness 54 to 58 sharpness 8 gamma 2.2 ( not sure if im to use 2.2 bt1886 or 2.4. Black level low warm 2 setting. Ive gotta be doing something wrong. Default contrast is 80 on Isf bright room and dark room brightness is 50. Somethings gotta give.
1 - 5 of 5 Posts
