Status
Not open for further replies.
1 - 2 of 2 Posts
Decided to paint my wall with Behr SS. What type of primer should I use? What type of roller should I use? Sanding is not a problem...
Optoma H30:
800 Lumens
2000:1 Contrast
Any quality latex primer will be fine. I used Kilz 2 latex primer. With the rollers you want to get a good quality 1/4" or 3/8" nap(The paint guy really liked Purdy rollers, that's what I used).
1 - 2 of 2 Posts
Status
