Just bought an open box VSX1124 last night. It's open box because it didn't have a remote, but other than that it looks like nothing was ever taken out of the box.
I setup all the cables just fine and am using the Wiring Nav on my iPad to set it up. It was going fine till I got to the part "plug in the MCACC mic and follow the on screen instructions".
I plug in the mic and nothing happens, no OSD shows up on the tv all. If I hit Next on the app it thinks for a sec like it's going to do MCACC but the just reloads the page where it explAins how to plug it in!
I tried unplugging the mic, put it back, turn on and off the system etc and nothing works. And now I noticed that there is a red light on the front of the reciever on for "MCACC", which I'm assuming (maybe incorrectly) it lights up when the mic is plugged in? Except it's on now while the mic is not plugged in!
So any suggestions? Am I screwed till I buy the actual remote for it, or is it maybe actually defective? I also could not find a way in the app to start the MCACC setup either, other than thru the Wiring Nav webpage it brought up.
