just a thought...don't forget that if you let the plasma overlap each side too much you may not be able to open the doors on the right side unit.
Originally Posted by clemsontiger10 just a thought...don't forget that if you let the plasma overlap each side too much you may not be able to open the doors on the right side unit. |
Originally Posted by calv1n Did you put it on an articulating arm mount? If so do you have any shots of it fully extended and what is the range of the tilt? Just curious I have a large articulated mount but its still in the box and I haven't had a chance to really look at it yet. Cheers |
