I believe I just made a mistake in purchasing the MX-500. Is there a simple way to program discrete codes in the MX-500 (assuming there is no coressponding remote button) or is the process so complicated that it would be worth the $75 difference to have the MX-700.
Can someone please verify that the MX-700 comes with everything necessary to program discrete codes directly into the remote.
Thanks for the assistance.
