Status
Not open for further replies.
1 - 2 of 2 Posts
I'm trying to get mx700 to control Panny plasma TH42PHD6UY. Namely want to be able to use discrete code for component and s-video input command. (PC command works fine). Downloaded prontoedit and corresponding ccf file. Copied discrete code.
Used Universal Browser to download learned buttons. All other functions work perfectly except S-video and component buttons. I'm stumped. Are there new codes?
Also trying to control over Cable, Scientific Atlanta 3100HD. Downloaded the mxd file from remotecentral. Downloaded settings from computer to remote, but box won't respond.
Simple questions I'm sure, but as new user I'm stuck. Help appreciated.
From your other post, it appears that your Panny has different discretes than previous models. Regarding the 3100HD, if the .mxd file you downloaded doesn't work, just learn the commands from your 3100HD remote. With the MXEditor's batch learning feature, it will take less than two minutes to learn the entire remote.
1 - 2 of 2 Posts
Status
