1 - 5 of 5 Posts
I have a Panasonic PT AE4000U projector. When I flip the main switch, the "stand by" red light turns on, then I press the power button, it turns green and I can hear the projector start up and the "temp" light blinks red instantly. Then after about a minute I hear the projector shut down and the "stand by" light goes red again and the temp light continues flashing red. No light comes out of the projector, so I can't work with a menu or anything. It is a brand new Projector so I'm confused on what the problem could be...help!!!?
where'd you get it from?
RETIRED theater builder
Zac, welcome to our forum. You need to realize that the AVSforum is compartmentalized into topical areas. You are way off course. Go to the owners thread about that projector for more advice.
1 - 5 of 5 Posts
