Status
Not open for further replies.
1 - 2 of 2 Posts
I have a 5040,I am having problems with my replay TV and would like to know if there is a way to reset it via the hardware instead of software. Let me explain why, I have tried to do it by pressing in I think it is 243 plus zone then hitting number two which clears the program guide and am supposed to go back and do it again and then go to seven. But it takes for ever to do that and i am not sure if it has in fact cleared the guide. I think because I've tried to so many times that it is confused and it just takes absolutely for ever to reboot, that is why I am asking if there is a hardware way of doing this so I can do fresh start.unless you do know of a way to do it with a remote that will be quicker. Thank you so much in advance for your help.
Simon :(
382 Replay Zones will do a factory reset.
All shows will be lost.
All configuration data will be lost.
i.e. it will be in the same condition as when it arrived from the factory.
1 - 2 of 2 Posts
Status
