1 - 2 of 2 Posts
My speakers are probably 15 years old or so...they are Rock Solids (by B&W). I've got two pair that I use currently. For a center channel I've got a old Pioneer that "works" but it not the best. I would like to find a decent center to match what I have sound-wise. I'm not sure I'll find something equally matching or if I should dump it all and start new. I don't have a ton to spend on speakers - so I would have to do a complete speaker setup for about $1000 or so.
Rest of the audio equip.
Denon AVR-2105
Denon DCM-320
M&K VX-7 sub
PS3 for Blu-ray & DVD
any thoughts?
Well,.. there is a pair on e-bay right now for $9.99, you could buy them and use one for the center.
On the other hand, there are a number of decent systems you could pick up for less than $1000.
1 - 2 of 2 Posts
