I have a Cambridge Soudworks sub that is 12
' with a 300 watt amp. My problem is it will go into protective mode if I turn the gain past halfway or the movie gets into a scene with heavy bass. I'd like to fix it myself since the Mass based company wants you to send it half way around the country to fix it.
Does it sound like the amp and can you find one other than from the company to fix it. Thanks
