1 - 2 of 2 Posts
· Registered
Hello,
I bought a used NAD M15 pre/pro and I am having problems getting the OSD to display. I have hooked up the monitor out for component, S-video, and composite and haven't had any luck. I think that the volume button activates the OSD for a split second while hooked via component but then flickers off.
Perhaps it is a problem with hooking up to my Sony 46v4100 screen. The OSD is 480i and my TV can't handle it.
Can any owners out there give me some tips on how to get the OSD up and running?
Thanks in advance.
· Registered
Dynaudio Heritage, Contour 25Ci, Simaudio M400 and 280D, Arcam AV860, Luxman 509X, LG 77 CX
HI, I have an M15.
I will start with the obvious questions first. You are changing to the correct input on your tv to view OSD?
You are using the enter button in the center ring on your NAD remote to bring up OSD? Volume has nothing to do with bringing up OSD.
I use component with no issues. I can help you with additional questions just let me know.
1 - 2 of 2 Posts
