Originally Posted by bluer101 /forum/post/0
I adjusted my Denon reciever to LFE + Main and set my fronts to large.
Why?
Why would you set your speakers to LARGE and use the LFE+Main setting to get rid of
subwoofer nulls or to improve your subwoofers' performance?
The LFE+Main setting sends redundant bass that would normally
only go to the LARGE fronts, to the subwoofers, as well. So, if you do this,
exactly the same bass signal (that is, LFE + bass below your crossover setting) will be sent to your subs as would be if you simply set your speakers to SMALL.
With your setup, you should run your fronts as SMALL. They're more suited to be run as SMALL. Using the LFE+Main setting with LARGE fronts only augments, via the subwoofer(s), the bass (not LFE) that is sent to your front L+R speakers. The front speakers still receive the same information, LFE+Main or not. That setting does nothing to the LFE and the subwoofer(s) still receives the same exact information that it would receive if you ran the speakers as SMALL. So that setting only increases the amount of front L+R channel bass, not "subwoofer bass".
Make sense?
Have you tried switching your subs' and front speakers' positions so that your subs are in front of the speakers and out further into the room? Corners are usually good for subs, but they shouldn't be smushed all the way into the corners.
