1 - 2 of 2 Posts
Here's the problem: youtube.com/watch?v=sDZoJoeXgCg
I own a pair of Studiophile Bx8 monitors, and today one of them started with this odd behavior. The other works fine, and I've swapped everything to determine it is the monitor itself. Since the tweeter isn't working either, this looks like a component issue and I'm hoping someone has some guidance for how to fix this.
The YT volume is low but it sounds like there is a LF constant hum, then when pressing on the cone, you are distorting the parallel travel of the voice coil around the magnet.
If the hum is constant and only on one channel, there is a malfunction in the output channel. Since it is humming smoothly, I would look at a fault in the output drive circuitry.
1 - 2 of 2 Posts
