Status
Not open for further replies.
1 - 2 of 2 Posts
Putting the finishing touches on my HT. Could use some help with the ceiling color.
The carpeting is a black/grey. The side walls will have a chair rail...with a burgandy on the bottom half and a dark green on the top half. The screen wall will be black
I'm trying to avoid having a black ceiling, due to the front screen color and the carpeting (just too much black)...and other ideas? Has anyone done a grey that looks sharp?
Thanks!!
Premium Member
You'll find a lot of info in the builders forum. Here is an example of a good thread on HT colors from that forum:
http://www.avsforum.com/avs-vb/showt...hreadid=436265
As far as grey. If you use the term "kodak grey" in the builders forum search engine, you'll find some good info. I used to have that color and went to black. I'm glad I did....never too much black.
Ron
1 - 2 of 2 Posts
Status
