1 - 3 of 3 Posts
Having had two runs of failures to color match GOM Claret Accent, I was wondering if any of you out there successfully color matched it and, if so, do you have to recipe/brand.
depends on your lighting i guess. with my lighting, the paint i used matches pretty good IMO.
Here is the paint. I used 2 coats.
1 - 3 of 3 Posts
