I just bought a used Panasonic TB50 TBC. It's a broadcast-quality TBC, but it came without a manual.
I'm not sure I'm hooking things up properly, but there do not seem to be any indicator lights on the device. When I turn the power switch on, it makes a few "squeaks" (they sound like something a piezo element might make) and there's a rapid clicking noise from the region of the power transformer on the back left of the unit.
There's also a fan on the back right of the unit, but it does not spin up.
Is this normal?
Please help if you're at all familiar with this unit.
Is this normal?
