I need a little advice regarding the placement of surrounds in a 5.1 system. This is a living room, not a dedicated home theater, so compromises, compromises...
A picture is worth 1,000 words, so have a look.
A few limitations:
1) I realize in a 5.1 system the surrounds should technically be on the side walls and pointed in toward the main listening position. However, the speaker wire was already run inside the walls and relocating it isn't an option.
2) the speakers are well above the recommended 2-3 feet above ear level. Obvious, it's a very open floor plan and I do not have a back wall and the right wall opens to a hallway.
3) I know in-walls or in-ceilings are probably a better solution, but I already have a matching Ascend 5.1 system and I really love the sound and look of it. Also, I've never heard an in-wall or in-ceiling that I really liked.
Things I've tried:
1) mounting the speakers flush against the wall... I really couldn't hear the surround effects at all. Not good.
2) angling the speakers toward (but not directly at) the main listening position. I haven't had a chance to run Audyssey again, but I can hear surround effects much better now. They are too loud, but I think that's to be expected. Pretty good.
I pointed the speakers at an imaginary point in the center of the room. I call it the optimum listening position. If I form an equilateral triangle with my left and right speakers, it's that point. The main listening position is about 4 feet further back (compromises... compromises). In theory, it's kind of like having the surround speakers shooting 2-3 feet above my head.
I don't want to open a can of worms here, but I've read a lot of debate about ambience vs discrete surround effects. To be honest, I'm not sure what my preference is. After angling the speakers toward the main listening position, movies sound much fuller with more depth and I really can't localize the surround effects - I can just tell right or left and that it's not coming from the fronts. It sounds really good, but some precise effects - like pans - lack a specific location like i think the sound engineer intended.
Any suggestions? What else should I try? What would you do?
Two quick notes: I've been testing with a few scenes from Inception, The Dark Knight, and Kung Fu Panda. I need to get my hands on a copy of Master and Commander! Also, I don't think the tweeter in my CBM-170 SE is aimable.
P.S. don't mind my daughter... She's home sick today
but she is sitting in the main listening position
A few limitations:
Things I've tried:
