Status
Not open for further replies.
1 - 3 of 3 Posts
I’m trying to connect my PC to my Panasonic 47WX49 HD Television.
I have the following:
· Gforce 3 card with the latest drivers
· An Audio Authority 9A60 VGA-to-Component Video Converter
· Power Strip 3
· I changed the monitor driver to the Sony w-900
· I running Windows 2000 with SP2
No matter which resolution I run I can’t get the vertical sync to work. Any advice would greatly be appreciated.
Make sure you pick "custom timings" on the first page otherwise they won't take.
Does it take on PC and not HDTV or no go on PC?
Any message come up?
Blue
1 - 3 of 3 Posts
Status
