Status
Not open for further replies.
1 - 2 of 2 Posts
hello all this is my first post. I just got a barco data 500 last week, used it for 2 days and it quit on me. I was playing xbox on it and the power cut off. I changed the main fuse's as per curt palm and found 1 blown. now i have power again but i have no power the the picture tube's. My board has a rcu error light on it. what is the rcu and what is that error. what can i do to fix it. i just want to know is that the remote control becouse my remote seems fine. i dont have instructions or i would not be asking.
Dave
Hey Dave, I tried emailing you back 3 x, but my emails kept getting bounced back showing errors at your end. I was hoping you'd post here..:)
I believe you told me that while you have standby power, the set will not power up, ie, the fans never start spinning, right?
If so, you have a bad power supply. I can fix that if you want. THe RCU light is simply telling you that the set isn't powering up, thus the error light.
Shoot me an email to [email protected] if my shaw address isn't working for you. That's my backup email address.
Curt
1 - 2 of 2 Posts
Status
