I have a Samsung HLR5087W that I bought about 2 years ago..the problem Im having with this tv set is that whenever you turn on the tv, it would display a still image of white and black pixel but you are still able to hear the noise from whatever program is showing. I try using the remote to change "sources" or "channel" and it seems to blink for a mini second and its back to the still image of white and black pixel.
There is no mechanical noise whenever i turn the set on, as some people have post that whenever there is a noise then it might be the color wheel. well in this case, there is no noise but the picture is still..so can it still the the color wheel thats causing the problem? The lamp is fine, as I recently change it out not too long ago.
Any suggestion would be appreciated. Thanks.
