1 - 3 of 3 Posts
I am nearing the point where I need to order my screen. I have decided on the Seymour Center Stage XD AT to go with my Panny 4000. I was hoping to use a 10' wide 2.35 screen but I don't think I have the height. The room is 14'x30' with an 8' ceiling.
The 2x4 is exactly 10' and the top is at 73.5". My math says that with a 3" border the bottom edge of the screen will only be 16" off the floor. Is this acceptable or should I be installing a narrower screen to get it up higher?
Seating will only be one row.
With one row seat screen bottom should be approximately between 24" and 36" from the floor
My screen is only 18" from the floor and I haven't found it causes any problems. My ceilings are low and I had to do this to make it work. Even from the back row the screen is very watchable.
1 - 3 of 3 Posts
