OK, quick rundown on setup. I have a set of M&K LCR 750THX mains plus the matching center 750 in the front. I have a pair of Definitive Technology ProCinema 80s and a pair of ProCinema 100s for the rear channel.
The rear channel sits about 5' above and about 2' behind the listening position. The L&R mains sit about 15 feet forward of the listening position and again about 5' above. The center channel sits about 15' forward and about 2' above.
All of this is being run from a Denon AVR4802.
The problem I'm having is that the sound is not as immersive as I would have expected. I've checked phase and everything is fine there. I'm running most of the time on the factory Home Theater THX or the Dolby Digital signal processing off the amp. I've messed with some aspects of timing via mucking around with the amp's input for speaker distance but it's still not very immersive.
Should I lower my mains off the ceiling? Would that help? Anything else I can play with?
TIA
~Sentinal
TIA
~Sentinal
