Please help, I am moving into a new home with a less than ideal setting for a home theater. My room is about 24' long and 12' deep. One 12' wall has french doors while the other has a large window. My couch will be placed on one of the 24' walls with openings on both sides of the couch. My monitor will be placed off center on the other 24' wall (fireplace is center). I am concerned about placement of speakers with an off center monitor. I will be installing a 7.1 config. So my questions are:
1)Can or should I put one of the mains on the other fireplace or do they need to be equidistant from the monitor?
2)Should the side surrounds be placed close to the seating area or at the ends of the 24' wall?
3)How far out from the wall does my couch need to be if I place the rear surrounds on the back wall facing down?
I will be using the following speakers
Mirage 260s for the mains, CC for center, and 4 Omnisats as surrounds with a Velodyne sub.
Sorry for the long message, but I am stumped. Any suggestions would be appreciated. Thanks.
Mike
Mike
