I am running HD through an HDTV Wonder card (MMC Software) to a plasma via DVI:HDMI. Our local NBC is the only channel that seems to stay on. I have excellent reception (93% - 98%) that doesn't fluctuate on every other major network but they come on for a few seconds and then go away with only audio remaining. The only thing I notice is that on the channel info, when the station is first selected it shows 1080i or 720p and then drops, usually to 480i or it will show a number greater than 1080i. It is after this drop that the image disappears. NBC starts at 1080i and stays there.
I have heard of the blackout problems some have experienced with this card but I am not sure if this is the same. Any help or advice would be greatly appreciated as I would like to change the channel.
Jason
AMD 64 3200
X600
HDTV Wonder
Jason
AMD 64 3200
X600
HDTV Wonder
