Status
Not open for further replies.
1 - 1 of 1 Posts
Im new to HTPC's and I just bought a New KV-32HS500 32-inch FD Trinitron® WEGA® Hi-Scan® TV. Featuring a Hi-Scan 1080i™ Display, DRC™ MultiFunction (960i or 480p) Circuitry, CineMotion™ Reverse 3-2 PullDown Technology, Auto 16:9 Enhanced Mode. This TV is also 720p Input Capable (converted to 1080i) and HD Capable. Im connected using DVI to DVI and the only resolutions the TV will accept is 640*480 and 1920*540. Im fine with using 640*480 I just have a half inch underscan. I would like to use the entire screen if possible. Tried power strip but it always goes out of sync while trying to fine tune. Will I only be able to get 1080i with a component connection?
1 - 1 of 1 Posts
Status
