1 - 5 of 5 Posts
I have a video problem with my hc1600. I'm trying to hook up a home theater surround sound system. my blue ray player only has an hdmi output and my hc 1600 projector does not seem to want to display the video. any ideas. I already changed the output to 720p on the blue ray player and that doesn't work. any help?
Are you using an AVR for the sound ? If so make sure HDMI passthrough is enabled so it doesn't upconvert to 1080p. Try hooking the BR player directly to the projector.
Discussion Starter · #3 ·
I have hooked the BR directly to the projector with the HDMI but my projector keeps saying no signal. I hooked the BR to my flat screen and manually set the video output to 720p and then hooked it up to the projector and still have no luck..
Their might be a problem with the HDMI port on the projector. Try and find or borrow another HDMI device to try on the projector, sometimes two HDMI devices just don't play nice with each other.
1 - 5 of 5 Posts
