just realized my wii has been hooked up to my hd65 projector as 480i, so i changed the setting on the wii to 480p...now the problem.
for some games, examples below, the screen will go blue for a few seconds and then resume normal...in the lower corner of the screen it will confirm the resolution and connection i.e. it appears to re-hunt for a connection, turns blue, and then re-connects. it doesn't do it in midst of the game but it does become annoying. when i changed the setting back to 480i, the problem went away...so its definitely the cause.
examples of when screen goes blue
- wii sports bowling - after you get a strike or make a split spare it will go blue...otherwise its ok
- smash brothers - after a battle session it will sometimes go blue
hoping someone has a solution for this problem. thx rob
