1 - 13 of 13 Posts
First, I wanted to say this is a great forum. The problem is I've been reading for a few days now, and it has become obvious how much I don't know about HT.
I'm needing some basic help that most of you would write off as elementary, so please take it easy on me.
Here's what I've purchased:
LG 42LH90 TV
Oppo BDP-83 Blue Ray player
I already had the receiver which is a Yamaha HTR-5540: can't post URL yet, so please let me know if you need any additional info on this.
For speakers I have the Bose AM-10.
My question revolves around the fact that my receiver is 7+ yrs old and does not have HDMI capability. I plan to run HDMI from blue ray player to tv so I can watch tv without always having surround turned on, but I'm trying to figure out specifically how to connect the surround to the receiver. Since I don't have HDMI on the receiver, what is the next best option to get the best sound possible? Both blue ray and receiver have optical, coax and analog connections and I need help deciding which set up to use.
Any help on this would be greatly appreciated, and I apologize if this has been addressed before.
Optical or coax would be best.
+1 - the Optical or COAX is your best option from the BluRay to your receiver.
Discussion Starter · #4 ·
Thank you both for the quick reply!
I need to clarify something...when I said analog, I meant multi-channel analog. Also, I want to run something by you to get your opinions.
I was just reading the user manual for the oppo and it indicated if I can't use HDMI I should use multi-channel analog. I'm attaching an exerpt from the manual for you to see:
NOTE
• Due to bandwidth limitations, high resolution audio formats such as Dolby Digital Plus,
Dolby TrueHD, DTS-HD High Resolution and DTS-HD Master Audio cannot be sent
through the coaxial or optical digital audio output. A reduced resolution version of the
same audio track will be output instead. To listen to high resolution audio formats in
their best quality, please use the HDMI connection if you have a receiver that handles
HDMI audio (see page 13) or use the multi-channel analog outputs if you do not (see
page 14).
• Due to copyright restrictions, SACD audio cannot be sent through the coaxial or
optical digital audio output. To listen to SACD, please use the HDMI or analog audio
connections.
• Due to copyright restrictions and bandwidth limitations, full resolution audio from DVDAudio
discs cannot be sent through the coaxial or optical digital audio output. To listen
to DVD-Audio in full resolution, please use the HDMI or analog audio connections.
End quote.
I am not second guessing you, but rather the manual as I've always heard analog was inferior to the other options.
Thoughts? I'm getting more confused by the minute...
If you want to take advantage of "hi-rez" audio, then multichannel analog audio interconnects are your only option if you don't have HDMI. You seem to have answered your own question/concern.
Discussion Starter · #6 ·
Ratman,
Thanks for your help, and yes, I guess I did answer my own question.
However, when you don't know what you don't know...sometimes seeing the answer yourself isn't enough. Thank you again!
Your receiver cannot do the new audio codec's, so going with Optical or COAX is your best bet. Saves running multiple wires.
Discussion Starter · #8 ·
Marlin,
Will the Oppo not do that before sending it to the receiver? I've no idea.
Not true Marlin...
The audio is decoded for hi-rez in the DVD player before it gets to the receiver as indicated in bullet #1:
their best quality
, please use the HDMI connection if you have a receiver that handles HDMI audio (see page 13) or use the multi-channel analog outputs if you do not (see page 14).
He's fine.
Originally Posted by Ratman /forum/post/18272201
Not true Marlin...
He's fine.
Good point - I forgot about that.
Sorry!
Discussion Starter · #11 ·
Thank you both for your help. Now, any suggestions on which wires I should buy and a good place to get them???
Any audio cables will work just fine. You can use three pair of red/white cables if you have them laying around. Just be sure to match each end (for each channel) correctly.
1 - 13 of 13 Posts
