My suggestions....
1) Get a Digital Cable box that has component inputs from your cable company.... You may need to buy the HD pack as well from your cable company to get it.... Yes... It may be time to bite the bullet and upgrade your cable package... Either that or keep using the Infocus X1 which gave a little better than ok picture for analog channels....
2) Put up a smaller picture for analog inputs... such as letter box a 4:3 image within a wide-screen image...
Personally, I have never tried any analog inputs since I only use Digital Cable and Component Inputs through progressive mode usually 1080i or 720p.... So, I can't help you much more than that... I feel my "analog" channels on the Digital Cable box look "ok" in the letterbox screen.... The Digital Cable channels look much better and the HD channels and the Movie channels look "awesome"!
