Status
Not open for further replies.
1 - 5 of 5 Posts
I recently purchased the Zenith 520 and I have connected it to my X1 via the RGB cable provided with the X1. The 520 is set to native and when I attempt to get HDTV stations from D* all I get is a message stating " searching for source" and flicker every so often. The only format that displays a picture is the 480p format which of course is not HDTV. Yes the switch in the back for DVI and Component is in the right position.
What is the best cable to use for HDTV with the X1?
Do I need a breakout cable or I'am I just doing something wrong?
Discussion Starter · #5 ·
GWLAW, Thanks for the quick response. I have seen alot of talk about that adapter, I just was not sure if I "had" to have it .
Thanks again
1 - 5 of 5 Posts
Status
