I just downloaded ZP 2.6 and The new patch for PowerDVD 4.0XP.
When I went to register filters for PowerDVD with WinDVD audio, it came up with "clvsd.ax can't be found". The funny thing is, before I downloaded the new versions of these two programs, everything was the same (ZP 2.5 and PowerDVD 4.0XP trial) and it worked fine. I know, don't break it if it ain't fixed!!! I just thought it was time to finally register PowerDVD, since it was coming up on the 30 day trial.
Anyway, if anyone has any ideas, or is it possible to just get the missing file and be on my way? The only other .ax files in that folder are clarc.ax and cldxva.ax, and neither of them work. I already tried to edit the filter.
Thanks in advance,
Tom
Thanks in advance,
Tom
